Introduzione
In the event that the lens cover is not functioning properly, either permanently opened or closed, it is necessary to align it properly on its spring arm.
Parti
Nessuna parte richiesta.
Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  • Locate and remove the silver screws on each side of the camera.
  • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
Aggiungi Commento
Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
  • Then, carefully pry apart the front and back outer casing away from the internal components.
  • Be aware of the ribbon wire that will disconnect when the casing is detached.
Aggiungi Commento
Place the internal electronics face-up. Look at the side with the flash turned towards you.
  • Place the internal electronics face-up. Look at the side with the flash turned towards you.
  • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
  • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
Aggiungi Commento
If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
  • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
  • Inside the yellow circle, the arm is in the correct position.
Aggiungi Commento
Conclusione
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membro da: 11/03/2013
28 Reputazione
5 Guide realizzate
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
7 Guide realizzate
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 496
