Introduzione
The scanner unit allows the user to scan documents onto their computer and/or copy and print original document.
Strumenti
Parti
Nessuna parte richiesta.
Locate data USB cable.
  • Locate data USB cable.
Aggiungi Commento
Locate the end of the cable that plugs into the printer.
  • Locate the end of the cable that plugs into the printer.
Aggiungi Commento
Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent. Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
  • Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
Aggiungi Commento
Locate the USB end of the cable. Insert that end into your computer.
  • Locate the USB end of the cable. Insert that end into your computer.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Turn wireless connection on your computer off and on. Sometimes doing this step is needed to have a connection.
  • Turn wireless connection on your computer off and on. Sometimes doing this step is needed to have a connection.
  • Check the network to make sure the computer and printer are connected to the same network.
Aggiungi Commento
Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off. Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off. Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off.
  • Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off.
Aggiungi Commento
  • Move the printer close to the router to ensure a strong connection.
Aggiungi Commento
Make sure the transparent cover is clean. If not, wipe the glass screen with a polishing cloth. If there is still debris on the glass, try spraying it with a cleaning solution and wiping it again.
  • Make sure the transparent cover is clean. If not, wipe the glass screen with a polishing cloth. If there is still debris on the glass, try spraying it with a cleaning solution and wiping it again.
Aggiungi Commento
If the print not is not clear, make sure the original document is flat on the glass. If the print out is still not clear, try finding a clearer version of your original document.
  • If the print not is not clear, make sure the original document is flat on the glass. If the print out is still not clear, try finding a clearer version of your original document.
Aggiungi Commento
  • If above steps do not solve the problem, try re-installing the drive for the printer.
Aggiungi Commento
Conclusione
Once your connection is set and that the screen is clear of any debris, you should be able to scan, copy and print documents.
Raymond
Membro da: 15/01/2013
42 Reputazione
7 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 784
