Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier. Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier. Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
Aggiungi Commento
Remove battery, prying from the provided gap at the upper-right corner of the battery Remove battery, prying from the provided gap at the upper-right corner of the battery
  • Remove battery, prying from the provided gap at the upper-right corner of the battery
Aggiungi Commento
Depress MicroSD to eject it from the side of the case. Depress MicroSD to eject it from the side of the case.
  • Depress MicroSD to eject it from the side of the case.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads. Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads. Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
Aggiungi Commento
Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures. Start at the top, and work clockwise, being careful not to break the clips. There are, 1, 3, 2, and 3 clips on each side, respectively.
  • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
  • Start at the top, and work clockwise, being careful not to break the clips.
  • There are, 1, 3, 2, and 3 clips on each side, respectively.
  • After the clips are disengaged, there are no cables holding the back panel in place.
Aggiungi Commento
Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
  • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
Aggiungi Commento
Remove 2 Phillips Screws holding the logic board to the front panel. Gently lift the logic board off the front panel.
  • Remove 2 Phillips Screws holding the logic board to the front panel.
  • Gently lift the logic board off the front panel.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,823
