Introduzione
This guide will show how to replace the speaker on the Casio camera
Parti
Nessuna parte richiesta.
Remove the four screws on the side with the speaker
  • Remove the four screws on the side with the speaker
Aggiungi Commento
Remove the four screws from the bottom of the camera.
  • Remove the four screws from the bottom of the camera.
  • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly
Aggiungi Commento
Remove the four screws on the side opposite of the speaker.
  • Remove the four screws on the side opposite of the speaker.
Aggiungi Commento
Pull apart the bottom casing.
  • Pull apart the bottom casing.
Aggiungi Commento
Remove ribbon from the rear casing. Set aside rear casing.
  • Remove ribbon from the rear casing.
  • Set aside rear casing.
Aggiungi Commento
Use tweezers or prongs to pry the LCD screen off from the opening. Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  • Use tweezers or prongs to pry the LCD screen off from the opening.
  • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
Aggiungi Commento
Lift up the LCD screen, slowly move it to the other side. Lift up the LCD screen, slowly move it to the other side.
  • Lift up the LCD screen, slowly move it to the other side.
Aggiungi Commento
Pry off the LCD casing which is taped on to the frame. Pry off the LCD casing which is taped on to the frame.
  • Pry off the LCD casing which is taped on to the frame.
Aggiungi Commento
Flip open the connector holding the ribbon. Pull out the LCD screen with the ribbon from the camera. Pull out the LCD screen with the ribbon from the camera.
  • Flip open the connector holding the ribbon.
  • Pull out the LCD screen with the ribbon from the camera.
Aggiungi Commento
Pull apart the front casing. Pull apart the front casing.
  • Pull apart the front casing.
Aggiungi Commento
Remove two screws on the side where the battery is located. Remove the lanyard loop after the screws come off.
  • Remove two screws on the side where the battery is located.
  • Remove the lanyard loop after the screws come off.
  • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
Aggiungi Commento
On the front of the camera near the flash flip the connector holding the ribbon. Remove the ribbon from the connector.
  • On the front of the camera near the flash flip the connector holding the ribbon.
  • Remove the ribbon from the connector.
Aggiungi Commento
Carefully remove the L shaped frame from the camera At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
  • Carefully remove the L shaped frame from the camera
  • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
  • Pop the frame off the bumps and tabs.
  • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  • The blue box is the speaker
Aggiungi Commento
Remove the speaker with tweezers
  • Remove the speaker with tweezers
Aggiungi Commento
Conclusione
Christian
Membro da: 28/01/2011
320 Reputazione
3 Guide realizzate
Cal Poly, Team 4-38, Regan Winter 2011 Membro di Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,511
