Salta al contenuto principale
Repair Mouse Buttons
Cosa ti serve
  1. Repair Mouse Buttons, Engage Wired Optical Mouse Top and Outer Shell Removal: passo 1, immagine 1 di 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Repair Mouse Buttons: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Repair Mouse Buttons: passo 3, immagine 1 di 3 Repair Mouse Buttons: passo 3, immagine 2 di 3 Repair Mouse Buttons: passo 3, immagine 3 di 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Repair Mouse Buttons: passo 4, immagine 1 di 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Repair Mouse Buttons: passo 5, immagine 1 di 2 Repair Mouse Buttons: passo 5, immagine 2 di 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Repair Mouse Buttons, Top Shell: passo 6, immagine 1 di 1
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  7. Repair Mouse Buttons, Repair Mouse Buttons: passo 7, immagine 1 di 2 Repair Mouse Buttons, Repair Mouse Buttons: passo 7, immagine 2 di 2
    • Take the plastic buttons (the part that your fingers click) and flip them over.
    • On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
  8. Repair Mouse Buttons: passo 8, immagine 1 di 2 Repair Mouse Buttons: passo 8, immagine 2 di 2
    • File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
    • Make sure to file down both towers. In this image, one is left un-filed to show the difference.
    • This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
Conclusione
Altre 20 persone hanno completato questa guida.
David
Membro da: 01/16/13
1.171 Reputazione
4 Guide realizzate
Cal Poly, Team 18-36, Regan Winter 2013 Membro di Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Membri
30 Guide realizzate
16 Commenti
Thanks, worked like a charm.
Michael Beckman - Replica
i used a software fix and all my double random clicks has gone , mouserepair.com solved my problem for good.
Youns T -
What if my gaming mouse doesnt have screws??
k2snakalle123 - Replica
yep no screws……….so am screwed
Nav Dugal -
Really a great help!
Aman Kashyap - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 374
Tutti i Tempi: 120,345
