Introduzione
Use this guide to remove the camera's outer case in order to gain access to and repair other parts.
Parti
Nessuna parte richiesta.
Locate the 2 screws on the bottom of the slider.
  • Locate the 2 screws on the bottom of the slider.
  • Remove both screws with a #00 Phillips screwdriver.
Aggiungi Commento
Gently pull on the bottom of the slider until it comes off the lower track.
  • Gently pull on the bottom of the slider until it comes off the lower track.
  • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
Aggiungi Commento
Lift the slider up until it comes off the upper track.
  • Lift the slider up until it comes off the upper track.
Aggiungi Commento
The slider should now be free from the body of the camera.
  • The slider should now be free from the body of the camera.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
Aggiungi Commento
Use the spudger to peel off the outer metal band, starting from the bottom of the camera. The metal band it attached to the camera with glue in addition to screws.  Be careful not to bend the band when removing it from the camera.
  • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
  • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
Aggiungi Commento
The shutter button can now be removed. It is not connected to the camera and can be lifted off. The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
Aggiungi Commento
Remove the memory card. Locate and remove the 2 screws using a #00 Phillips screwdriver.
  • Remove the memory card.
  • Locate and remove the 2 screws using a #00 Phillips screwdriver.
Aggiungi Commento
Use a spudger around the edge of the case to loosen it. Carefully wiggle the back case off. This may require a fair amount of force. Carefully wiggle the back case off. This may require a fair amount of force.
  • Use a spudger around the edge of the case to loosen it.
  • Carefully wiggle the back case off. This may require a fair amount of force.
Aggiungi Commento
Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
Aggiungi Commento
While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required. Be careful not to completely pull the front case off because it will still be connected with wires.
  • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
  • Be careful not to completely pull the front case off because it will still be connected with wires.
Aggiungi Commento
Conclusione
Jared Ruekberg
Membro da: 15/04/2010
24 Reputazione
2 Guide realizzate
Cal Poly, Team 6-13, Maness Spring 2010 Membro di Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,056
