Salta al contenuto principale
Removing the HP Elitebook 6930p Switch Cover
Cosa ti serve
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, immagine 3 di 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, immagine 3 di 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: passo 3, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 3, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 3, immagine 3 di 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: passo 4, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 4, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 4, immagine 3 di 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, immagine 3 di 3
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: passo 6, immagine 1 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 6, immagine 2 di 3 Removing the HP Elitebook 6930p Switch Cover: passo 6, immagine 3 di 3
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
Conclusione
Altre 4 persone hanno completato questa guida.
Richdave
Membro da: 04/09/10
32.150 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.463 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,965
