Introduzione
This guide will show you how to remove the optical (cd) drive from your HP Compaq dx2000MT.
Parti
Nessuna parte richiesta.
Turn off your computer and remove the power cable by pulling it straight out of its socket.
  • Turn off your computer and remove the power cable by pulling it straight out of its socket.
Aggiungi Commento
Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
  • Remove the 2 Phillips #2 screws that secure the case door to the device.
Aggiungi Commento
Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
  • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
  • Once you slide the door back, remove it by pulling it outwards from the device.
Aggiungi Commento
Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
Aggiungi Commento
Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
Aggiungi Commento
Remove the 2 Torx T15 screws holding the optical drive in place. Remove the 2 Torx T15 screws holding the optical drive in place.
  • Remove the 2 Torx T15 screws holding the optical drive in place.
Aggiungi Commento
Remove the other 2 Torx T15 screws holding the other side of the drive in place. Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
Aggiungi Commento
Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device.
  • Remove the optical drive by sliding it out the front of the device.
Aggiungi Commento
Conclusione
Logan Pace
Membro da: 12/10/2011
2.020 Reputazione
15 Guide realizzate
Cal Poly, Team 17-16, Regan Fall 2011 Membro di Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,130
