Introduzione
This guide is base on the official service manual which I have attached to the device page and has been created using photos contained in other iFixit guides.
Parti
Nessuna parte richiesta.
Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
  • Place the laptop upside down on a clean, flat surface.
  • Locate the battery release button with the padlock symbol above it.
  • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
  • Gently remove the battery from the side of the laptop.
Aggiungi Commento
Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
  • Place laptop upsid down on a clean flat work surface.
  • Remove the Philips M2.5 x 8 mm screw
  • Loosen the screw that holds the memory compartment closed
  • remove the memory module compartment cover
  • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Aggiungi Commento
Conclusione
Richdave
Membro da: 09/04/2010
27.897 Reputazione
37 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
727 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 262
