Salta al contenuto principale
Removing Olympus FE-210 Rear Casing
Cosa ti serve
  1. Removing Olympus FE-210 Rear Casing, Battery: passo 1, immagine 1 di 2 Removing Olympus FE-210 Rear Casing, Battery: passo 1, immagine 2 di 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Rear Casing: passo 2, immagine 1 di 2 Removing Olympus FE-210 Rear Casing: passo 2, immagine 2 di 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Rear Casing, Front Casing: passo 3, immagine 1 di 3 Removing Olympus FE-210 Rear Casing, Front Casing: passo 3, immagine 2 di 3 Removing Olympus FE-210 Rear Casing, Front Casing: passo 3, immagine 3 di 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Rear Casing: passo 4, immagine 1 di 3 Removing Olympus FE-210 Rear Casing: passo 4, immagine 2 di 3 Removing Olympus FE-210 Rear Casing: passo 4, immagine 3 di 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Rear Casing, Rear Casing: passo 5, immagine 1 di 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Rear Casing: passo 6, immagine 1 di 3 Removing Olympus FE-210 Rear Casing: passo 6, immagine 2 di 3 Removing Olympus FE-210 Rear Casing: passo 6, immagine 3 di 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
Conclusione
Matt
Membro da: 01/25/11
811 Reputazione
6 Guide realizzate
Cal Poly, Team 4-36, Regan Winter 2011 Membro di Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,578
