Introduzione
The screen of the Nokia 3100b is prone to cracking. This guide shows you how to access the screen and remove it.
Parti
Nessuna parte richiesta.
Make sure your phone is turned off.
  • Make sure your phone is turned off.
Aggiungi Commento
Press the button on the back of the phone and slide the back panel off.
  • Press the button on the back of the phone and slide the back panel off.
  • Remove the battery by pulling it from the phone.
Aggiungi Commento
Note the small metal frame that  hold the SIM card into place.
  • Note the small metal frame that hold the SIM card into place.
  • Gently pull back the tab and lift open the frame.
Aggiungi Commento
Retrieve your SIM card.
  • Retrieve your SIM card.
Aggiungi Commento
Separate the front cover from the main body of the phone.
  • Separate the front cover from the main body of the phone.
  • Set the front cover, as indicated, aside.
Aggiungi Commento
Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
  • Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
  • Removing the screws in this order prevents any unnecessary torsion on the circuit board. Be sure to remove the screws in the order indicated.
Aggiungi Commento
Pull the screen assembly from the base of the phone.
  • Pull the screen assembly from the base of the phone.
  • Set the base of the phone, as indicated, aside.
Aggiungi Commento
Carefully lift the keypad portion of the screen assembly from the circuit board.
  • Carefully lift the keypad portion of the screen assembly from the circuit board.
Aggiungi Commento
Separate the screen from the circuit board.
  • Separate the screen from the circuit board.
  • Note the components circled in orange. These will need to be reconnected during reassembly in order for the screen to function.
  • Set the circuit board, as indicated, aside.
  • Remember to reconnect the screen to the circuit board when reassembling!
Aggiungi Commento
Gently push down on the screen to pop it off of the assembly.
  • Gently push down on the screen to pop it off of the assembly.
Aggiungi Commento
When the screen falls out the assembly, two white tabs will fall out with it.
  • When the screen falls out the assembly, two white tabs will fall out with it.
  • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Aggiungi Commento
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,605
