Salta al contenuto principale
Removing Nikon Coolpix 4100 Viewer
Cosa ti serve
  1. Removing Nikon Coolpix 4100 Viewer, Opening the Case: passo 1, immagine 1 di 1
    • Tool on left - PH000 screwdriver
    • Tool on right - iPod fix-it tool
    • Soldering Iron
  2. Removing Nikon Coolpix 4100 Viewer: passo 2, immagine 1 di 1
    • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
  3. Removing Nikon Coolpix 4100 Viewer: passo 3, immagine 1 di 2 Removing Nikon Coolpix 4100 Viewer: passo 3, immagine 2 di 2
    • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
  4. Removing Nikon Coolpix 4100 Viewer: passo 4, immagine 1 di 1
    • Use the iPod fix-it tool to separate the back panel from the camera.
  5. Removing Nikon Coolpix 4100 Viewer, LCD screen: passo 5, immagine 1 di 1
    • Use the iPod fix-it tool to carefully pry the screen from the logic board.
    • There's a ribbon cable that connects the screen to the logic board.
  6. Removing Nikon Coolpix 4100 Viewer: passo 6, immagine 1 di 1
    • This view shows the ribbon cable that connects to the screen.
  7. Removing Nikon Coolpix 4100 Viewer: passo 7, immagine 1 di 1
    • Flip the screen down. To disconnect the ribbon cable from the logic board, rock each end of the brown metal retainer that holds the ribbon cable in place until the ribbon disconnects.
  8. Removing Nikon Coolpix 4100 Viewer: passo 8, immagine 1 di 1
    • Remove the two screws on the top edge of the circuit board to the right of the viewfinder.
  9. Removing Nikon Coolpix 4100 Viewer: passo 9, immagine 1 di 1
    • To connect the new screen, solder the wires in place and connect the ribbon cable to the logic board.
  10. Removing Nikon Coolpix 4100 Viewer: passo 10, immagine 1 di 1
    • Unthread the four wires running across the top of the viewfinder from the plastic brackets holding them in place.
  11. Removing Nikon Coolpix 4100 Viewer: passo 11, immagine 1 di 1
    • Remove the two black screws threaded vertically into the top of the viewfinder. Loosen the flash and circuit board for more accessibility. This will allow for the viewfinder to be replaced.
  12. Removing Nikon Coolpix 4100 Viewer, Viewer: passo 12, immagine 1 di 2 Removing Nikon Coolpix 4100 Viewer, Viewer: passo 12, immagine 2 di 2
    • Remove the small piece of tape holding the four wires to the viewer.
  13. Removing Nikon Coolpix 4100 Viewer: passo 13, immagine 1 di 2 Removing Nikon Coolpix 4100 Viewer: passo 13, immagine 2 di 2
    • Remove the two screws on the top edge of the circuit board, to the right of the viewer.
Conclusione
Andrew
Membro da: 09/27/12
7 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Buehl Fall 2012 Membro di Ohio State, Team 1-2, Buehl Fall 2012
OSU-BUEHL-F12S1G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 912
