Introduzione
Step-by-step guide to removing your phone's antenna.
The antenna is located on top right corner of the phone while the front of the phone is facing you. Unscrew the antenna clockwise until it is loose enough to remove from the phone. Unscrew the antenna clockwise until it is loose enough to remove from the phone.
  • The antenna is located on top right corner of the phone while the front of the phone is facing you.
  • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Conclusione
Elizabeth OBrien
Membro da: 26/04/2010
31 Reputazione
14 Guide realizzate
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,838
