Salta al contenuto principale
Removing HP Compaq dx2000MT Power Supply
Cosa ti serve
  1. Removing HP Compaq dx2000MT Power Supply, Removing the HP Compaq dx2000MT Case Doors: passo 1, immagine 1 di 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Power Supply: passo 2, immagine 1 di 2 Removing HP Compaq dx2000MT Power Supply: passo 2, immagine 2 di 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Power Supply: passo 3, immagine 1 di 3 Removing HP Compaq dx2000MT Power Supply: passo 3, immagine 2 di 3 Removing HP Compaq dx2000MT Power Supply: passo 3, immagine 3 di 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Power Supply: passo 4, immagine 1 di 3 Removing HP Compaq dx2000MT Power Supply: passo 4, immagine 2 di 3 Removing HP Compaq dx2000MT Power Supply: passo 4, immagine 3 di 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Power Supply, Power Supply: passo 5, immagine 1 di 3 Removing HP Compaq dx2000MT Power Supply, Power Supply: passo 5, immagine 2 di 3 Removing HP Compaq dx2000MT Power Supply, Power Supply: passo 5, immagine 3 di 3
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  6. Removing HP Compaq dx2000MT Power Supply: passo 6, immagine 1 di 2 Removing HP Compaq dx2000MT Power Supply: passo 6, immagine 2 di 2
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  7. Removing HP Compaq dx2000MT Power Supply: passo 7, immagine 1 di 3 Removing HP Compaq dx2000MT Power Supply: passo 7, immagine 2 di 3 Removing HP Compaq dx2000MT Power Supply: passo 7, immagine 3 di 3
    • Remove the 4 Torx T15 screws from the rear of the power supply
  8. Removing HP Compaq dx2000MT Power Supply: passo 8, immagine 1 di 2 Removing HP Compaq dx2000MT Power Supply: passo 8, immagine 2 di 2
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
Conclusione
Altre 8 persone hanno completato questa guida.
Logan Pace
Membro da: 10/12/11
2.224 Reputazione
9 Guide realizzate
Cal Poly, Team 17-16, Regan Fall 2011 Membro di Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,364
