Introduzione
Removing front panel to replace main LCD or small display screen.
Parti
Nessuna parte richiesta.
Using the plastic opening tool, pry off the top faceplate.
  • Using the plastic opening tool, pry off the top faceplate.
  • Place the tool in the small crack that runs along the side of the phone and pry.
Aggiungi Commento
Using the T6 Torx Screwdriver remove all 4 small screws.
  • Using the T6 Torx Screwdriver remove all 4 small screws.
Aggiungi Commento
Remove silver plate from phone.
  • Remove silver plate from phone.
Aggiungi Commento
Using the spudger remove the plastic camera casing
  • Using the spudger remove the plastic camera casing
Aggiungi Commento
Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
Aggiungi Commento
Use Spudger or hands to detach flex cable from front screen logic board
  • Use Spudger or hands to detach flex cable from front screen logic board
Aggiungi Commento
Conclusione
Cecilia
Membro da: 11/04/2010
1 Reputazione
3 Guide realizzate
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,801
