Flip the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  • Flip the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  • The back cover is the access point for the user-removable battery. Removing the back cover also gives the user access to the hard-reset button.
Aggiungi Commento
Locate the large button on the top back of the device. This button is used to release the latch holding the sliding back cover in place. Press this button at the top while making a firm grip on the battery cover. As the button is pressed, move the cover towards the bottom of the device while applying moderate pressure to the cover.
  • Locate the large button on the top back of the device. This button is used to release the latch holding the sliding back cover in place.
  • Press this button at the top while making a firm grip on the battery cover.
  • As the button is pressed, move the cover towards the bottom of the device while applying moderate pressure to the cover.
  • Be careful to not press down too hard on the battery cover as it is made of plastic.
  • The battery removal tab may pop up during the cover removal process.
Aggiungi Commento
After the cover is removed, the white Lithium Ion battery is visible.
  • After the cover is removed, the white Lithium Ion battery is visible.
Aggiungi Commento
Conclusione
Scott Byer
Membro da: 09/03/2012
61 Reputazione
5 Guide realizzate
Clemson, Team 1-2, Benson Spring 2012 Membro di Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,254
