Salta al contenuto principale
Removing Bottom of iMac G4 15" 700 MHz EMC 1873
Cosa ti serve
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: passo 1, immagine 1 di 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: passo 1, immagine 2 di 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: passo 2, immagine 1 di 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: passo 3, immagine 1 di 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: passo 3, immagine 2 di 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: passo 4, immagine 1 di 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: passo 5, immagine 1 di 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: passo 6, immagine 1 di 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: passo 6, immagine 2 di 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: passo 7, immagine 1 di 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: passo 8, immagine 1 di 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 5-32, Amido Fall 2011 Membro di Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Membri
8 Guide realizzate
Un commento
Do I need to apply thermal paste? Or it is not necessary?
willynanita - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 6,325
