Introduzione
There are a few reasons to want to take out your backseat:
  • Clean under it.
  • Put in a new seat.
  • To reach the rear speakers.
And this is a short and easy guide on how to remove the seat. Anyone can do it.
Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
  • Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
Aggiungi Commento
Pull/lift the tab/lever on each side to release the seat.
  • Pull/lift the tab/lever on each side to release the seat.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Lift up and remove the seat.
  • Lift up and remove the seat.
Aggiungi Commento
Clean the seat or do whatever it is you wish to do. Clean the seat or do whatever it is you wish to do.
  • Clean the seat or do whatever it is you wish to do.
Aggiungi Commento
Put the seat back on. As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back. As shown in the second image is a hook that goes into the base of the backseat.
  • Put the seat back on.
    • As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back.
    • As shown in the second image is a hook that goes into the base of the backseat.
    • The third image is of the tab that the hook on the seat goes into.
  • When you line up the hooks and tabs, push down hard. You will hear a click when the hooks are fitted into the tabs.
  • And there, your seat has been taken out and put back in! Good job!
Aggiungi Commento
Conclusione
Your seat has now been taken out and put back in. Not hard, eh?
Altre 4 persone hanno completato questa guida.
Scratchitory
Membro da: 25/04/2013
890 Reputazione
3 Guide realizzate
Will back seats out of a 2004 or 5 grand Prix gt fit in 2003 SS Monte Carlo. Help please
Perry monahan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 145
Tutti i Tempi: 6,184
