Introduzione
To begin, make sure to remove the battery before doing anything else.
Make sure that the computer is turned off and is disconnected from external power source.
  • Make sure that the computer is turned off and is disconnected from external power source.
  • Turn it upside down and locate the battery release switch.
Introduction: Parts: Need to add the Fan Part Numbers
Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
John Frazier - Replica
While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  • While holding the switch in the open position, lift out the battery.
  • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Aggiungi Commento
Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment. These screws hold the hard drive tray into the hard drive compartment.
  • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
  • These screws hold the hard drive tray into the hard drive compartment.
Aggiungi Commento
Slide the hard drive tray out of the hard drive compartment.
  • Slide the hard drive tray out of the hard drive compartment.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Malik Shahbal
Membro da: 05/10/2010
429 Reputazione
6 Guide realizzate
Cal Poly, Team 22-5, Maness Fall 2010 Membro di Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 45
Tutti i Tempi: 17,893
