Introduzione
This guide will lead you through the steps necessary to access the screen's components as well as how to assure it is properly connected.
Parti
Nessuna parte richiesta.
Flip the device over
  • Flip the device over
Aggiungi Commento
Unscrew the 2 screws closest to the screen
  • Unscrew the 2 screws closest to the screen
Aggiungi Commento
Flip the device back over
  • Flip the device back over
  • It is now standing right side up
Aggiungi Commento
Unscrew the top.
  • Unscrew the top.
Aggiungi Commento
Take the top of the device off.
  • Take the top of the device off.
Aggiungi Commento
Unscrew the button board.
  • Unscrew the button board.
Aggiungi Commento
Take off the button board.
  • Take off the button board.
Aggiungi Commento
Unscrew all visible screws on the black logic board cover.
  • Unscrew all visible screws on the black logic board cover.
Aggiungi Commento
Lift the screen straight up out of the device.
  • Lift the screen straight up out of the device.
Aggiungi Commento
Check that the single input plug from the logic board  to the screen (reverse side) is completely pushed in by pressing it firmly into the socket.
  • Check that the single input plug from the logic board to the screen (reverse side) is completely pushed in by pressing it firmly into the socket.
  • Also check that the 2 output plugs from the screen to the logic board are completely pushed in by pressing them firmly into the highlighted sockets.
  • You have successfully reconnected your display screen.
Aggiungi Commento
Conclusione
Nick Sherman
Membro da: 26/09/2012
31 Reputazione
1 Guida realizzata
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 338
