Salta al contenuto principale
Reattaching the GEN 2 Wheelchair Foot Support
Cosa ti serve
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, immagine 1 di 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, immagine 2 di 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, immagine 3 di 3
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: passo 2, immagine 1 di 1
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: passo 3, immagine 1 di 2 Reattaching the GEN 2 Wheelchair Foot Support: passo 3, immagine 2 di 2
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Conclusione
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Cal Poly, Team 14-8, Maness Spring 2013 Membro di Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 789
