Introduzione
Removing the ear cushions allows the user to begin disassembly of the rest of the device. If the ear cushion is damaged, it can also be replaced.
The ear cushions are removed from the device by slightly different methods.
  • The ear cushions are removed from the device by slightly different methods.
  • To remove the left ear cushion (the side with the boom), rotate the cushion counter clockwise as far as it can turn, then pull the ear cushion straight out from the device.
  • To remove the right ear cushion, rotate it clockwise as far as it can turn, then pull the ear cushion straight out from the device.
I dont understand
Victoria Weeden - Replica
In order to remove the cushion from the plastic backing, slide the leather free of the plastic edge, working around the entire cushion until it separates.
  • In order to remove the cushion from the plastic backing, slide the leather free of the plastic edge, working around the entire cushion until it separates.
Aggiungi Commento
Conclusione
Kyle Schober
Membro da: 24/02/2014
580 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,043
