Introduzione
Follow these steps to disassemble the drill and replace the planetary gear for the RIDGID R84015 X2 power drill.
Parti
Nessuna parte richiesta.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate. Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Aggiungi Commento
Remove the five screws attaching the drill handle.
  • Remove the five screws attaching the drill handle.
Aggiungi Commento
Remove the 4 screws attaching the front of the casing. Remove the 4 screws attaching the front of the casing.
  • Remove the 4 screws attaching the front of the casing.
Aggiungi Commento
Unscrew the four screws at the rear of the plastic gear chamber.
  • Unscrew the four screws at the rear of the plastic gear chamber.
Aggiungi Commento
Remove the motor from the drill. NOTE: Handle the gear chamber with caution as the gears are now loose.
  • Remove the motor from the drill.
  • NOTE: Handle the gear chamber with caution as the gears are now loose.
Aggiungi Commento
Remove the four screws that attach the plastic gear chamber.
  • Remove the four screws that attach the plastic gear chamber.
  • Remove the plastic gear chamber.
Aggiungi Commento
Remove each component from the gear assembly. Remove each component from the gear assembly.
  • Remove each component from the gear assembly.
Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Evan Long
Membro da: 15/04/2010
232 Reputazione
4 Guide realizzate
Cal Poly, Team 15-48, Garner Spring 2010 Membro di Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Membri
5 Guide realizzate
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,342
