Introduzione
RCA Small Wonders Camcorder cc176
May 1993
Remove the 5 screw securing the control panel on the top of the device. Use a small flathead screwdriver to loosen the panel from the device until you are able to remove it. Use a small flathead screwdriver to loosen the panel from the device until you are able to remove it.
  • Remove the 5 screw securing the control panel on the top of the device.
  • Use a small flathead screwdriver to loosen the panel from the device until you are able to remove it.
Aggiungi Commento
Remove the remaining 21 screws on the device. Begin separating the plastic casing from the inner components of the device. Begin separating the plastic casing from the inner components of the device.
  • Remove the remaining 21 screws on the device.
  • Begin separating the plastic casing from the inner components of the device.
Aggiungi Commento
Grasp the viewfinder in hand, and carefully remove the two screws securing the mounting device. Locate the gray electrical cord connecting the viewfinder to the inner component of the camera and gently unplug the gray cord and loosen the viewfinder from the device.
  • Grasp the viewfinder in hand, and carefully remove the two screws securing the mounting device.
  • Locate the gray electrical cord connecting the viewfinder to the inner component of the camera and gently unplug the gray cord and loosen the viewfinder from the device.
Aggiungi Commento
  • Separate the viewfinder from the plastic the device, feeding the gray cord through the hole in the plastic casing.
Aggiungi Commento
Conclusione
Allison Baudoin
Membro da: 05/12/2011
401 Reputazione
4 Guide realizzate
James Madison, Team 2-1, Allen Fall 2011 Membro di James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 904
