Introduzione
This guide will show you how to take off and replace the screen of your Lyra.
Parti
Nessuna parte richiesta.
Using slight pressure with your finger on the word "OPEN", slide the battery plate down. Remove the battery plate. Place your finger at the bottom of the battery.
  • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
  • Remove the battery plate.
  • Place your finger at the bottom of the battery.
  • Lift up on the battery until it pops out from the LYRA X2400.
Aggiungi Commento
Remove two Phillips screws from the silver cover at the top of the Lyra. Slowly wiggle the silver cover while pulling it away from the device.
  • Remove two Phillips screws from the silver cover at the top of the Lyra.
  • Slowly wiggle the silver cover while pulling it away from the device.
Aggiungi Commento
Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button. Pull the silver case from the bottom of the device.
  • Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
  • Pull the silver case from the bottom of the device.
Aggiungi Commento
Carefully pry up the screen with a plastic opening tool. Disconnect the screen's ribbon cable  from the circuit board. Remove the screen.
  • Carefully pry up the screen with a plastic opening tool.
  • Disconnect the screen's ribbon cable from the circuit board.
  • Remove the screen.
Aggiungi Commento
Conclusione
Emmett
Membro da: 11/04/2013
1 Reputazione
1 Guida realizzata
Cal Poly, Team 17-3, Regan Spring 2013 Membro di Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 180
