Introduzione
Use this guide to replace the USB port of the RCA Lyra X2400.
Remove two Phillips screws from the silver cover at the top of the Lyra. Slowly wiggle the silver cover while pulling it away from the device.
  • Remove two Phillips screws from the silver cover at the top of the Lyra.
  • Slowly wiggle the silver cover while pulling it away from the device.
Aggiungi Commento
Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button. Pull the silver case from the bottom of the device.
  • Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
  • Pull the silver case from the bottom of the device.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully pry up the screen with a plastic opening tool. Disconnect the screen's ribbon cable  from the circuit board. Remove the screen.
  • Carefully pry up the screen with a plastic opening tool.
  • Disconnect the screen's ribbon cable from the circuit board.
  • Remove the screen.
Aggiungi Commento
Open the case of the Lyra. Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  • Open the case of the Lyra.
  • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Aggiungi Commento
Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located. Start using solder/desolder tools to remove the USB in/out.
  • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
  • Start using solder/desolder tools to remove the USB in/out.
  • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Aggiungi Commento
Conclusione
Joseph Goodwin
Membro da: 11/04/2013
1 Reputazione
5 Guide realizzate
Cal Poly, Team 17-3, Regan Spring 2013 Membro di Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 139
