Introduzione
This guide will instruct on how to replace a malfunctioning Viewfinder assembly on the RCA CC310.
Parti
Nessuna parte richiesta.
Slide a spudger between the plastic rail and the metal tab on the left side of the rail.  Push away from the camcorder to release the flap. Pushing the viewfinder assembly to the right makes lifting the flap easier.
  • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
  • Pushing the viewfinder assembly to the right makes lifting the flap easier.
  • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
Aggiungi Commento
Unscrew the 7mm ph#0 screw on the underside where the cable connects. Lift the plastic where the cable connects off of the viewfinder assembly. Disconnect the cable inside by pulling it apart.
  • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
  • Lift the plastic where the cable connects off of the viewfinder assembly.
  • Disconnect the cable inside by pulling it apart.
Aggiungi Commento
Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly. Lift the viewfinder plastic assembly up and remove.
  • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
  • Lift the viewfinder plastic assembly up and remove.
Aggiungi Commento
Flip back the viewfinder access tab.
  • Flip back the viewfinder access tab.
  • Unscrew the 7.0mm ph #0 screw next to the mirror.
Aggiungi Commento
Lift off both sides of the plastic assembly. When reassembling, if the housing doesn't connect properly, try turning the focus wheel. When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  • Lift off both sides of the plastic assembly.
  • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
Aggiungi Commento
Lift the microphone circuit board straight up. Unclip the cable connected to the circuit board.
  • Lift the microphone circuit board straight up.
  • Unclip the cable connected to the circuit board.
Aggiungi Commento
Lift plastic housing and guide the wires from underneath. Lift out the entire circuit board and viewfinder. Replace entire circuit board and viewfinder assembly.
  • Lift plastic housing and guide the wires from underneath.
  • Lift out the entire circuit board and viewfinder.
  • Replace entire circuit board and viewfinder assembly.
Aggiungi Commento
Conclusione
Oliver Adams
Membro da: 19/01/2011
620 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,654
