Introduzione
This guide will instruct you to replace the onboard microphone if it is faulty.
Lift the metal flap and slide  the viewfinder off to the right. Lift the metal flap and slide  the viewfinder off to the right.
  • Lift the metal flap and slide the viewfinder off to the right.
Aggiungi Commento
Unscrew the 7.0mm ph#0 screw on the underside where the cable connects. Lift the plastic where the cable is connected to the viewfinder. Disconnect the cable inside by pulling it apart.
  • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
  • Lift the plastic where the cable is connected to the viewfinder.
  • Disconnect the cable inside by pulling it apart.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly. Lift the viewfinder plastic assembly up.
  • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
  • Lift the viewfinder plastic assembly up.
Aggiungi Commento
Lift the microphone circuit board straight up. Unclip the cable connected to the circuit board.
  • Lift the microphone circuit board straight up.
  • Unclip the cable connected to the circuit board.
Aggiungi Commento
Turn the microphone circuit board over.
  • Turn the microphone circuit board over.
  • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
Aggiungi Commento
Desolder the metal protective housing using a soldering iron.
  • Desolder the metal protective housing using a soldering iron.
  • Desolder the microphone and replace it.
Aggiungi Commento
Conclusione
Oliver Adams
Membro da: 19/01/2011
620 Reputazione
6 Guide realizzate
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 689
