Salta al contenuto principale
Prerequisite Exterior Housing Disassembly
Cosa ti serve
  1. Prerequisite Exterior Housing Disassembly, Exterior Housing: passo 1, immagine 1 di 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: passo 1, immagine 2 di 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iOpener
    $19.99
    Compra
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
Conclusione
To reassemble your device, apply double-sided tape or adhesive on the existing glue and fit the housing back on.
Jerrell
Membro da: 04/23/14
730 Reputazione
7 Guide realizzate
Cal Poly, Team 11-50, Amido Spring 2014 Membro di Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 267
