Salta al contenuto principale
PowerBook G4 Titanium DVI Airport Card Replacement
Cosa ti serve
  1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: passo 1, immagine 1 di 2 PowerBook G4 Titanium DVI Airport Card Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: passo 2, immagine 1 di 2 PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: passo 2, immagine 2 di 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Airport Card Replacement, Airport Card: passo 3, immagine 1 di 1
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
Conclusione
Altre 19 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 22,308
