Introduzione
Install an Airport Extreme 802.11g card internally.
Orient the computer so that the side with the line of screws on it is away from you.
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
Which screw driver I have to use here?
smartvideocanada - Replica
Phillips #00 Screwdriver: All necessary tools are available to buy at the top of this page if they are needed.
Sam Love -
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
Aggiungi Commento
Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Aggiungi Commento
Release the tabs on each side of the RAM chip at the same time.  These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
Aggiungi Commento
  • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
  • 2) After disengaging the locking bar, slide the cable out of the connector.
Where can I get a replacement clip for the ribbon cable?
applerepairshop - Replica
For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
  • For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
  • Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
  • Slide the trackpad cable out of the loosened connector.
  • When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
  • Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
Aggiungi Commento
Remove the following 10 screws from the bottom case:
  • Remove the following 10 screws from the bottom case:
    • Three 1.7 mm Phillips from the front edge of the battery compartment.
    • One 3.9 mm T8 Torx to the right of the memory card.
    • One 6.9 mm T8 Torx at the left edge of the memory compartment.
    • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
    • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
i believe that you have the torx screws reversed here. The longer one should go on the left and vise versa.
spatz - Replica
oops, my bad. You're right.
spatz - Replica
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
  • Turn the computer over and rotate it so that the DVI port faces you.
  • Remove the four identical Phillips screws spread along this edge of the case.
Aggiungi Commento
  • Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
Aggiungi Commento
Open the computer and turn it so that the screen faces you.
  • Open the computer and turn it so that the screen faces you.
  • Pull the upper case off, lifting from the back, and working around the edges.
Aggiungi Commento
Use a spudger to loosen the casing if it sticks.
  • Use a spudger to loosen the casing if it sticks.
  • Once the casing is entirely free, lift it off of the computer.
BE VERY CAREFUL when replacing the keyboard to thread the keyboard ribbon cable through the slot. The steps didn't appear to make this warning and when I replaced all screws, found that it was jammed and would not come through to connect with the connector. I had to undo a lot of steps to go back and rethread it properly.
Ted - Replica
Disconnect the orange ribbon from the right side of the modem, removing tape as necessary.
  • Disconnect the orange ribbon from the right side of the modem, removing tape as necessary.
Aggiungi Commento
Remove the three 4 mm hex nuts using a nut driver or needle-nosed pliers.
  • Remove the three 4 mm hex nuts using a nut driver or needle-nosed pliers.
Aggiungi Commento
Lift the modem partially out of the computer, disconnecting the modem cable before pulling it entirely away.
  • Lift the modem partially out of the computer, disconnecting the modem cable before pulling it entirely away.
Aggiungi Commento
Place the computer on edge (with the display open).
  • Place the computer on edge (with the display open).
  • Remove the black bumper and disconnect the Airport Extreme cable beneath it.
Aggiungi Commento
Back inside the computer, disconnect the Airport antenna cable at the gold connector, making sure you pull only on the gold metal portion of the connector.
  • Back inside the computer, disconnect the Airport antenna cable at the gold connector, making sure you pull only on the gold metal portion of the connector.
Aggiungi Commento
If you have not already done so, disconnect the hard drive ribbon and PC card cage ribbon from the left side of the logic board.
  • If you have not already done so, disconnect the hard drive ribbon and PC card cage ribbon from the left side of the logic board.
How you do that, please ?
jeromelourtioux - Replica
Remove the four Phillips screws from the corners of the PC card cage.
  • Remove the four Phillips screws from the corners of the PC card cage.
  • The longer screws go on the right side of the PC card cage.
Aggiungi Commento
In the following step, the connector you disconnected from the underside of the logic board may catch as you're pulling the card cage out. Of course, the same issue may arise when putting a card cage back into the computer.
  • In the following step, the connector you disconnected from the underside of the logic board may catch as you're pulling the card cage out. Of course, the same issue may arise when putting a card cage back into the computer.
  • Hold the PC card cage on the left side and pull it out of the computer.
Aggiungi Commento
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
To unplug the antenna from the laptop, just separate the golden parts.
Fabrice - Replica
Slide the Airport card from the back of the PC card cage.
  • Slide the Airport card from the back of the PC card cage.
Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 24/09/2009
1 Reputazione
745 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 22,511
