Introduzione
The heat sink and fan together help to keep the processor cool and happy.
Use a coin to turn the battery locking screw 90 degrees to the right.
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
Aggiungi Commento
Remove the four Phillips screws from the memory door.
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
Aggiungi Commento
Remove the long black Phillips screw next to the memory card.
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
Aggiungi Commento
On the keyboard, remove the F1, F2, F11, and F12 keys.
  • On the keyboard, remove the F1, F2, F11, and F12 keys.
  • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
  • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
  • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
Aggiungi Commento
Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
  • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
Aggiungi Commento
Remove the two short Phillips screws.
  • Remove the two short Phillips screws.
Aggiungi Commento
Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
  • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
Aggiungi Commento
Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
  • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
Pull straight up, not sideways. I used tweezers on the connector, rather than pulling on the ribbon cable.
vmile - Replica
mine had foil tape over the connector
Avi Fagan - Replica
Carefully lift edges of foil tape across logic board connector end of keyboard cable (foil is present if unit
has not been apart before).
Grasp cable near the connector and gently pull straight up (perpendicular to logic board).
John Haruguchi - Replica
Remove the three small Phillips screws from within the battery compartment.
  • Remove the three small Phillips screws from within the battery compartment.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Turn the computer 90 degrees clockwise and remove the two medium-length Phillips screws from the casing.
  • Turn the computer 90 degrees clockwise and remove the two medium-length Phillips screws from the casing.
Aggiungi Commento
Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
  • Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
By bottom screw, it means the screw nearer the lid, not the screw nearer the bottom of the computer
cantoi - Replica
Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
  • Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
  • Remember these two screws are longer and have shoulders.
Aggiungi Commento
Turn the computer over and open it up.
  • Turn the computer over and open it up.
  • Remove the following 14 screws:
    • Six 2.5 mm Phillips on either side of the keyboard area.
    • Five 4.5 mm Phillips on the left half of the keyboard area.
    • One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
    • One 15 mm Phillips in the upper middle of the keyboard area.
    • One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
Aggiungi Commento
Peel up the two pieces of foil tape on the left side of the keyboard area.
  • Peel up the two pieces of foil tape on the left side of the keyboard area.
  • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
At least on my own PowerBook G4 12” 867MHz, the microphone and power cables are long enough that I was able to do the hard drive replacement without disconnecting those connections. I basically had to flip the top case over to the left rather than removing it straight upward. I guess that makes some of the subsequent steps slightly tricky, but at least for me, the tradeoff was worth it.
Barry Nathan - Replica
Use the orange plastic loop to disconnect the trackpad cable.
  • Use the orange plastic loop to disconnect the trackpad cable.
Aggiungi Commento
Starting at one of the upper corners near the screen, work around the frame, separating the upper case from the lower case.
  • Starting at one of the upper corners near the screen, work around the frame, separating the upper case from the lower case.
Aggiungi Commento
Lift the upper case off the computer.
  • Lift the upper case off the computer.
can't lift upper case off. upper case.. it anchored on display side !!!
Fernando - Replica
Remove the two Phillips screws from the corners of the modem.
  • Remove the two Phillips screws from the corners of the modem.
Aggiungi Commento
Pry the modem up from the trackpad side.
  • Pry the modem up from the trackpad side.
Aggiungi Commento
Disconnect the modem cable from the modem.
  • Disconnect the modem cable from the modem.
Aggiungi Commento
Remove the single Phillips screw fastening the inverter cable.
  • Remove the single Phillips screw fastening the inverter cable.
Aggiungi Commento
Disconnect the Bluetooth cable and deroute it.
  • Disconnect the Bluetooth cable and deroute it.
Aggiungi Commento
Peeling up yellow tape as necessary, remove the following 8 screws:
  • Peeling up yellow tape as necessary, remove the following 8 screws:
    • One 4.5 mm Phillips on the right side of the heat sink.
    • Three 6 mm Phillips near the display.
    • Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
    • Two 13 mm screws from the left side of the heat sink and the right side of the fan.
For step 31 I had a problem where the screws with the springs just kept turning. While I did not have this problem the first time I disassembled the board, it was because I did not tighten the screws on the board (the studs on the actual logic board, not the ones you use to fasten the heat sink to the board) before reassembling. If you encounter the same problem, the screws aren't necessarily stripped but the actual piece attached to the board has become loose and just keeps turning. To get them off I used Vise grips and pulled up while turning until i got them off and it took a while. Moral of the story: tighten the pieces actually attached to the board before reassembling. Sorry, I don't know how else to describe the types of screws used but the stud is attached to the board and that is what came loose.
zerokool - Replica
Remove the yellow tape to free the cable from the left side of the heat sink.
  • Remove the yellow tape to free the cable from the left side of the heat sink.
Aggiungi Commento
Disconnect the fan cable from the logic board.
  • Disconnect the fan cable from the logic board.
Aggiungi Commento
Remove the orange tape on the trackpad side of the fan to free the fan cable.
  • Remove the orange tape on the trackpad side of the fan to free the fan cable.
Remove the silver plate that was under the modem. Gives better access to the orange tape.
kwackman - Replica
Grasp the heat sink near the copper conductor and lift it out of the computer, freeing it from tape and cables as necessary.
  • Grasp the heat sink near the copper conductor and lift it out of the computer, freeing it from tape and cables as necessary.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 24/09/2009
1 Reputazione
750 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 9,019
