Introduzione
Remove the rear display bezel to access your LCD and inverter.
Use a coin to turn the battery locking screw 90 degrees to the right.
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
What can I say?
It is certainly do able. I just completed it. Took me 2 hours. The most important tool you'll need is patience - bag full of patience!!
Gopal - Replica
Took 3 1/2 to 4 hours for someone who is handy but has never opened a computer before. Not so bad and it was a fun learning experience.
Nomad Toes - Replica
Quote from Nomad Toes:
Weird. I posted this on Step 1 of replacing the optical drive, but it showed up on the RAM page since Step 1 is the same. Replacing the RAM takes 10 minutes.
Open the computer and rotate the display as far as possible.
  • Open the computer and rotate the display as far as possible.
  • Remove the T6 Torx screw from the bottom left corner of the display assembly. The computer casing will not allow the screwdriver to be inserted directly into the screw, so be careful not to strip the screw.
Aggiungi Commento
Remove the T6 Torx screw from the bottom right corner of the display assembly.
  • Remove the T6 Torx screw from the bottom right corner of the display assembly.
  • To avoid cross-threading these screws during reinstallation, use a pair of tweezers to start each screw in its hole before using your Torx screwdriver to tighten them.
Aggiungi Commento
The next steps involve the use of plastic opening tools and spudgers which will probably be ruined in the process.  Have a few spares of each tool handy. Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD. Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
  • The next steps involve the use of plastic opening tools and spudgers which will probably be ruined in the process. Have a few spares of each tool handy.
  • Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
  • Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
  • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
  • Freeing these tabs may require some force. Be sure to support the display assembly with your other hand to avoid putting too much strain on the hinges.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD. Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel. Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  • Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
  • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Aggiungi Commento
Close the display. The rear display bezel is still attached to the display via the antenna cables. Lift the bottom edge of the rear display bezel up about an inch.
  • Close the display.
  • The rear display bezel is still attached to the display via the antenna cables.
  • Lift the bottom edge of the rear display bezel up about an inch.
  • Slide the rear display bezel forward to release the clips along the top edge of the display.
  • Rotate the rear display bezel away from the display and lay it next to the computer.
Aggiungi Commento
Remove any tape covering the right antenna cable.
  • Remove any tape covering the right antenna cable.
  • De-route the antenna cable from the right side of the rear display bezel.
Aggiungi Commento
The antenna is attached to the rear display bezel via adhesive.  To remove it, place the flat end of a spudger behind the top edge of the antenna, and carefully twist the spudger to pop the antenna off. The antenna is attached to the rear display bezel via adhesive.  To remove it, place the flat end of a spudger behind the top edge of the antenna, and carefully twist the spudger to pop the antenna off.
  • The antenna is attached to the rear display bezel via adhesive. To remove it, place the flat end of a spudger behind the top edge of the antenna, and carefully twist the spudger to pop the antenna off.
Aggiungi Commento
Place the pointed end of the spudger behind the lower part of the antenna and carefully rotate the spudger to free the antenna from the rear display bezel.
  • Place the pointed end of the spudger behind the lower part of the antenna and carefully rotate the spudger to free the antenna from the rear display bezel.
Aggiungi Commento
Remove any tape covering the left antenna cable.
  • Remove any tape covering the left antenna cable.
  • De-route the antenna cable from the left side of the rear display bezel.
Aggiungi Commento
Remove the left antenna in the same way the right antenna is removed (shown above).
  • Remove the left antenna in the same way the right antenna is removed (shown above).
Aggiungi Commento
Conclusione
Documenti Allegati
Matthew Newsom
Membro da: 05/01/2010
30.930 Reputazione
89 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,969
