Introduzione
The power card connects your batteries to the computer.
Cosa ti serve
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
Remove the single Phillips screw from the modem.
Disconnect the orange PMU cable by pulling it directly up.
Push the display back so that it lies flat.
Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
Repeat the previous step on the left side.
Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
Remove the single black T8 Torx screw from the power card.
Grasp the power card near the black plastic shield toward the center of the case and lift up.
Altre 6 persone hanno completato questa guida.
Documenti Allegati
Un commento
I’ve determined that my Voltage Regulator PMU Charge Charger Card, 820-0917-A on the M4753 Powerbook G3 Wallstreet is burned out. I want to replace the burned out parts on the board. Is there a circuit board diagram somewhere on the internet? If so, please let me know for this. Thanks
