Introduzione
How to access the PowerBook G3 Pismo Clutch Cover.
Turn the keyboard locking screw so that it is parallel to the space bar.
  • Turn the keyboard locking screw so that it is parallel to the space bar.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Aggiungi Commento
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
  • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
Aggiungi Commento
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Aggiungi Commento
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
  • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
  • Lift the heat shield up and pull it toward you.
On my M7572, these are T9s not Philips.
Rufleyboy - Replica
Aggiungi Commento
Skip this step if your computer does not have an Airport card installed.
  • Skip this step if your computer does not have an Airport card installed.
  • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
  • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
On mine, the airport card had been put it with the orange ribbon OVER the top, so had to unplug the righthand connector and then plug it back in after (see pic for Step 8)
Rufleyboy - Replica
Disconnect the antenna cable from the Airport card.
  • Disconnect the antenna cable from the Airport card.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pull the battery cable directly up from the logic board.
  • Pull the battery cable directly up from the logic board.
  • Remove the battery from its holder by pulling up and to the left.
Aggiungi Commento
Aggiungi Commento
Remove the long silver Phillips #1 screw from the heat sink.
  • Remove the long silver Phillips #1 screw from the heat sink.
  • Remove the two T8 Torx screws that attach the heat sink to the processor.
Aggiungi Commento
Lift the heat sink up from the left side and pull it out.
  • Lift the heat sink up from the left side and pull it out.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Aggiungi Commento
Grasp the plastic tab on the processor's right side and pull it directly up.
  • Grasp the plastic tab on the processor's right side and pull it directly up.
  • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
Aggiungi Commento
Aggiungi Commento
Remove the black Torx screw from the right side of the modem.
  • Remove the black Torx screw from the right side of the modem.
  • Remove the small black plastic rectangle with four holes.
Aggiungi Commento
Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
  • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
Aggiungi Commento
Disconnect the cable from the right side of the modem.
  • Disconnect the cable from the right side of the modem.
Aggiungi Commento
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
Aggiungi Commento
Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
Aggiungi Commento
Aggiungi Commento
Push the display back so that it lies flat.
  • Push the display back so that it lies flat.
  • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Repeat the previous step on the left side.
Aggiungi Commento
Lift the clutch cover up and off, rotating it toward yourself.
  • Lift the clutch cover up and off, rotating it toward yourself.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 24/09/2009
1 Reputazione
750 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,615
