Introduzione
Install an original Airport 802.11b card internally.
Parti
Turn the keyboard locking screw so that it is parallel to the space bar.
  • Turn the keyboard locking screw so that it is parallel to the space bar.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Aggiungi Commento
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
  • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
Aggiungi Commento
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
  • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
  • Lift the heat shield up and pull it toward you.
On my M7572, these are T9s not Philips.
Rufleyboy - Replica
Aggiungi Commento
Skip this step if your computer does not have an Airport card installed.
  • Skip this step if your computer does not have an Airport card installed.
  • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
  • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
On mine, the airport card had been put it with the orange ribbon OVER the top, so had to unplug the righthand connector and then plug it back in after (see pic for Step 8)
Rufleyboy - Replica
Disconnect the antenna cable from the Airport card.
  • Disconnect the antenna cable from the Airport card.
Aggiungi Commento
Conclusione
Altre 15 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 24/09/2009
1 Reputazione
750 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 17,919
