Introduzione
Change out the entire display assembly, including the hinges and plastic casing.
Turn the computer so that the ports are facing you.
  • Turn the computer so that the ports are facing you.
  • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Aggiungi Commento
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
Aggiungi Commento
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • In order to replace the keyboard, you must first remove the modem.
Aggiungi Commento
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Aggiungi Commento
Lift the heat shield up and pull it toward you.
  • Lift the heat shield up and pull it toward you.
Aggiungi Commento
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Aggiungi Commento
Pull the battery cable directly up from the logic board.
  • Pull the battery cable directly up from the logic board.
Aggiungi Commento
Remove the battery from its holder by pulling up and to the left.
  • Remove the battery from its holder by pulling up and to the left.
Aggiungi Commento
Remove the two silver Phillips screws from the modem.
  • Remove the two silver Phillips screws from the modem.
Aggiungi Commento
Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
Aggiungi Commento
Free Shipping on all orders 79,00 US$ and up.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Disconnect the cable from the right side of the modem.
  • Disconnect the cable from the right side of the modem.
Aggiungi Commento
Aggiungi Commento
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Aggiungi Commento
Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
  • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
  • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
Aggiungi Commento
Aggiungi Commento
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip out.
  • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
Aggiungi Commento
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
Aggiungi Commento
Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
Aggiungi Commento
Push the display back so that it lies flat.
  • Push the display back so that it lies flat.
Aggiungi Commento
Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Repeat the previous step on the left side.
Aggiungi Commento
Lift the clutch cover up and off, rotating it toward yourself.
  • Lift the clutch cover up and off, rotating it toward yourself.
Aggiungi Commento
Grasp the orange display data cable and disconnect it from the logic board.
  • Grasp the orange display data cable and disconnect it from the logic board.
  • Pull the display cable straight up so that it is vertical.
Aggiungi Commento
Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
  • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
  • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
Aggiungi Commento
Disconnect the white inverter cable connector from the right end of the board.
  • Disconnect the white inverter cable connector from the right end of the board.
Aggiungi Commento
Disconnect the inverter plug, pulling directly up from the logic board.
  • Disconnect the inverter plug, pulling directly up from the logic board.
Aggiungi Commento
Aggiungi Commento
Turn the laptop around so that its back faces you.
  • Turn the laptop around so that its back faces you.
  • Open the port door located at the back of the laptop.
  • Remove the four black Torx screws.
Aggiungi Commento
Hold the display on both sides and pull directly up until its hinges are free of their mounts.
  • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
Aggiungi Commento
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 24/09/2009
1 Reputazione
745 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 6,866
