Salta al contenuto principale
PowerBook 3400 M3553 Keyboard Replacement
Cosa ti serve
  1. PowerBook 3400 M3553 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Keyboard Replacement: passo 2, immagine 1 di 2 PowerBook 3400 M3553 Keyboard Replacement: passo 2, immagine 2 di 2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Keyboard Replacement: passo 4, immagine 1 di 3 PowerBook 3400 M3553 Keyboard Replacement: passo 4, immagine 2 di 3 PowerBook 3400 M3553 Keyboard Replacement: passo 4, immagine 3 di 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Keyboard Replacement: passo 5, immagine 1 di 2 PowerBook 3400 M3553 Keyboard Replacement: passo 5, immagine 2 di 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-59, Amido Spring 2011 Membro di Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,181
