Remove the Ni-Cad battery from the PowerBook 180. Slide the arrows toward the front of the computer until the battery can slide out.
  • Remove the Ni-Cad battery from the PowerBook 180.
  • Slide the arrows toward the front of the computer until the battery can slide out.
Aggiungi Commento
Removing the screws securing the bottom plate from the PowerBook 180. There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  • Removing the screws securing the bottom plate from the PowerBook 180.
  • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Your computer should look like the two pictures after the bottom plate is removed. Your computer should look like the two pictures after the bottom plate is removed.
  • Your computer should look like the two pictures after the bottom plate is removed.
Aggiungi Commento
Locate the modem board, which is next to the DC-in port. There are two Torx T8 screws marked in red in the pictures.  Remove these screws and pull up on the modem board to remove.
  • Locate the modem board, which is next to the DC-in port.
  • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
  • To reassemble your PowerBook, follow these instructions in reverse.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Jack Byrnes
Membro da: 17/10/2010
1.148 Reputazione
2 Guide realizzate
Master Techs Membro di Master Techs
Community
276 Membri
718 Guide realizzate
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 962
