Salta al contenuto principale
Power Mac G5 Front Fan Assembly Replacement
  1. Power Mac G5 Front Fan Assembly Replacement, Side Panel: passo 1, immagine 1 di 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Front Fan Assembly Replacement: passo 2, immagine 1 di 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Front Fan Assembly Replacement: passo 3, immagine 1 di 2 Power Mac G5 Front Fan Assembly Replacement: passo 3, immagine 2 di 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Front Fan Assembly Replacement: passo 4, immagine 1 di 3 Power Mac G5 Front Fan Assembly Replacement: passo 4, immagine 2 di 3 Power Mac G5 Front Fan Assembly Replacement: passo 4, immagine 3 di 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Front Fan Assembly Replacement, Front Fan Assembly: passo 5, immagine 1 di 1
    • Locate the front fan assembly.
  6. Power Mac G5 Front Fan Assembly Replacement: passo 6, immagine 1 di 1
    • Pull the fan assembly out; it should slide out easily.
Conclusione
Altre 25 persone hanno completato questa guida.
Adam
Membro da: 01/22/10
831 Reputazione
3 Guide realizzate
Cal Poly, Team 5-8, Forte Winter 2010 Membro di Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 18,898
