Introduzione
This guide details the removal of the main fan from the fan housing.
Pull on outer latch. Lower door until it is level with your work surface.
  • Pull on outer latch.
  • Lower door until it is level with your work surface.
  • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Aggiungi Commento
Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver. The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
  • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
Aggiungi Commento
Remove the power cable from the fan and detach bracing.
  • Remove the power cable from the fan and detach bracing.
Aggiungi Commento
To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
  • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Stephen Scruggs
Membro da: 20/01/2010
2.017 Reputazione
2 Guide realizzate
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 6,093
