Introduzione
Sometimes users have trouble with static on their phone meaning the connection between the handset and base may be faulty. This guide shows how to replace the antenna on the base of the phone.
Parti
Nessuna parte richiesta.
Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw. Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw. Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
  • Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
Aggiungi Commento
Grasp the plastic antenna foot and pull toward you. Grasp the plastic antenna foot and pull toward you.
  • Grasp the plastic antenna foot and pull toward you.
Aggiungi Commento
Pull antenna from the top side of the phone base cover. It helps if you gently wiggle the antenna back and forth to loosen the clips.
  • Pull antenna from the top side of the phone base cover.
  • It helps if you gently wiggle the antenna back and forth to loosen the clips.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 173
