Introduzione
Being able to remove the keyboard will allow you to replace it or clean up the connections if the keyboard is not working properly.
Parti
Nessuna parte richiesta.
Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
  • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
  • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
Aggiungi Commento
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off! Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
  • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
Aggiungi Commento
Gently lift the internal keyboard off of the motherboard. Gently lift the internal keyboard off of the motherboard.
  • Gently lift the internal keyboard off of the motherboard.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 725
