Introduzione
The shutter switch is the button which is to be pressed when the user wants to capture an image. If for some reason this switch needs to be replaced, this guide will be showing how to remove the shutter switch.
Parti
Nessuna parte richiesta.
Begin by opening the top of the camera (flash assembly) to a slight angle. Next, angle the flash assembly slightly upward and pry off the connections carefully. Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  • Begin by opening the top of the camera (flash assembly) to a slight angle.
  • Next, angle the flash assembly slightly upward and pry off the connections carefully.
  • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
Lens Replacement Guide - Steps 5 through 8 need titles
Step 6 - remove first bullet
Step 2 - 3 need titles
Add titles to all steps of all guides
Primary lens replacement guide
Step 4 is not a step review titles for all steps.
hani - Replica
Proofread your guides carefully.
Dan Brown - Replica
Slide the action button, on the bottom of the camera, to open the bottom. Slide the action button, on the bottom of the camera, to open the bottom.
  • Slide the action button, on the bottom of the camera, to open the bottom.
Aggiungi Commento
Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose. Pull off the face plate. Pull off the face plate.
  • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
  • Pull off the face plate.
Aggiungi Commento
After the face plate is off, the shutter switch should slide out easily. After the face plate is off, the shutter switch should slide out easily. After the face plate is off, the shutter switch should slide out easily.
  • After the face plate is off, the shutter switch should slide out easily.
Aggiungi Commento
Conclusione
Tyler OBrien
Membro da: 22/09/2014
489 Reputazione
2 Guide realizzate
USF Tampa, Team 3-5, Brown Fall 2014 Membro di USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Membri
6 Guide realizzate
where did you get the replacement parts for this?
Jacob Sokolove - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,217
