Introduzione
This lens is what focuses the light on the mirror, and by extension the film, when taking photos. The shutter lies directly behind it. It is very easy to replace, as it only requires the removal of the front plate to access, and is held in place only by grooves into which it snaps into place. This guide will illustrate how to remove this primary lens.
Parti
Nessuna parte richiesta.
Begin by opening the top of the camera (flash assembly) to a slight angle. Next, angle the flash assembly slightly upward and pry off the connections carefully. Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  • Begin by opening the top of the camera (flash assembly) to a slight angle.
  • Next, angle the flash assembly slightly upward and pry off the connections carefully.
  • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
Lens Replacement Guide - Steps 5 through 8 need titles
Step 6 - remove first bullet
Step 2 - 3 need titles
Add titles to all steps of all guides
Primary lens replacement guide
Step 4 is not a step review titles for all steps.
hani - Replica
Proofread your guides carefully.
Dan Brown - Replica
Slide the action button, on the bottom of the camera, to open the bottom. Slide the action button, on the bottom of the camera, to open the bottom.
  • Slide the action button, on the bottom of the camera, to open the bottom.
Aggiungi Commento
Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose. Pull off the face plate. Pull off the face plate.
  • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
  • Pull off the face plate.
Aggiungi Commento
Once the front assembly is removed, the primary lens should be exposed without any trouble.
  • Once the front assembly is removed, the primary lens should be exposed without any trouble.
Aggiungi Commento
Use your spudger to leverage the lens from the groove at the top (red). Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
  • Use your spudger to leverage the lens from the groove at the top (red).
  • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 3-5, Brown Fall 2014 Membro di USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 387
