Salta al contenuto principale
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, immagine 1 di 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, immagine 2 di 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, immagine 3 di 3
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: passo 2, immagine 1 di 1
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: passo 3, immagine 1 di 1
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
Linea Traguardo
Altre 13 persone hanno completato questa guida.
Doug Jimenez
Membro da: 01/21/10
538 Reputazione
2 Guide realizzate
Cal Poly, Team 16-31, Maness Winter 2010 Membro di Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Membri
6 Guide realizzate
13 Commenti
It worked but its expensive
Jessica diaz - Replica
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - Replica
nothing happened
new film installed
no sound
no flash
no action
eminickstone - Replica
I'm having the same issue
Marie -
I'm having same issue.
Marie -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 368
Tutti i Tempi: 149,230
