Salta al contenuto principale
Polaroid LCD-0700P Case Replacement
Cosa ti serve
  1. Polaroid LCD-0700P Case Replacement, Case: passo 1, immagine 1 di 2 Polaroid LCD-0700P Case Replacement, Case: passo 1, immagine 2 di 2
    • Turn the entire device over, so that the underside of the device is facing upward.
    • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
  2. Polaroid LCD-0700P Case Replacement: passo 2, immagine 1 di 2 Polaroid LCD-0700P Case Replacement: passo 2, immagine 2 di 2
    • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
    • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Be careful when separating the front and back covers, as the two are held together by a thin wire.
    • Separate the halves of the case.
  3. Polaroid LCD-0700P Case Replacement: passo 3, immagine 1 di 1
    • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
Conclusione
Mario T
Membro da: 01/09/12
466 Reputazione
5 Guide realizzate
Cal Poly, Team 8-14, Maness Winter 2012 Membro di Cal Poly, Team 8-14, Maness Winter 2012
CPSU-MANESS-W12S8G14
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,881
