Salta al contenuto principale
Pokewalker Battery Replacement
Cosa ti serve
  1. Pokewalker Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Battery Replacement: passo 2, immagine 1 di 1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Battery Replacement: passo 3, immagine 1 di 1
    • Remove the Rear Cover from the Device
  4. Pokewalker Battery Replacement: passo 4, immagine 1 di 1
    • Use the flat end of a Spudger to Remove the Battery
Conclusione
Altre 8 persone hanno completato questa guida.
Winni Stuart
Membro da: 04/13/14
417 Reputazione
2 Guide realizzate
2 Commenti
The battery must be placed positive side facing up if I am correct.
I just dug my pokewalker out of my closet. Been years since it has been used. Putting in an effort to get it running again.
Thanks for the tutorial.
Jake Allen - Replica
I just got my Pokéwalker up and running again as well. Nintendo's stuff is always so well made.
signature -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 130
Ultimi 30 Giorni: 546
Tutti i Tempi: 25,406
