Introduzione
This guide takes you through installing the speakers in the PlayStation Vita.
Power off and remove the memory card. Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  • Power off and remove the memory card.
  • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Aggiungi Commento
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
  • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
Aggiungi Commento
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
Aggiungi Commento
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases. Continue working your way around the device gently prying it open. There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
  • Continue working your way around the device gently prying it open.
  • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
Aggiungi Commento
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Aggiungi Commento
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
Aggiungi Commento
Free the battery cable by gently prying up on the connection with a spudger.
  • Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
Jimbo Jones - Replica
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
ylimakiminna - Replica
Yea I messed up there too. Is there a way to fix it?
Alethia Henry - Replica
Separate the front and rear cases.
  • Separate the front and rear cases.
Aggiungi Commento
Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it. The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
  • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
  • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
What is that little connection point for, just above where the speaker sits. it has a single connection point on the side motherboard.
Chris Ramsay - Replica
Conclusione
Brittany McCrigler
Membro da: 05/03/2012
78.135 Reputazione
431 Guide realizzate
iFixit Membro di iFixit
Community
115 Membri
5.776 Guide realizzate
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - Replica
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 49
Tutti i Tempi: 5,296
