Introduzione
This guide takes you through the process of installing the 3G antenna cable on the PlayStation Vita. This is the black antenna cable on the left of the wireless.
Power off and remove the memory card. Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  • Power off and remove the memory card.
  • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Aggiungi Commento
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
  • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
Aggiungi Commento
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
Aggiungi Commento
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases. Continue working your way around the device gently prying it open. There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
  • Continue working your way around the device gently prying it open.
  • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
Aggiungi Commento
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Aggiungi Commento
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
Aggiungi Commento
Free the battery cable by gently prying up on the connection with a spudger.
  • Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
Jimbo Jones - Replica
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
ylimakiminna - Replica
Yea I messed up there too. Is there a way to fix it?
Alethia Henry - Replica
Separate the front and rear cases.
  • Separate the front and rear cases.
Aggiungi Commento
Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
  • Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
Aggiungi Commento
Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
  • Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
  • Deroute the 3G antenna cable out of the casing and remove it.
Aggiungi Commento
Conclusione
Brittany McCrigler
Membro da: 05/03/2012
78.125 Reputazione
431 Guide realizzate
iFixit Membro di iFixit
Community
116 Membri
5.774 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 5,450
